Tools & Fabrication - **welders important safety tip**
98FiveSeven
01-08-2012, 09:44 AM
Hey guys I found this on JEEPFORUM and didnt see anything here so I though I should repost as it could possibly save someones life!
http://www.brewracingframes.com/id75.htm
technical
01-08-2012, 10:16 PM
I saw that one a little while ago. I cringed while reading it.
MrElectric03
01-09-2012, 10:01 PM
Thanks for sharing ive never read that. Im going to post this at my shop where we use MIG somewhat often and brake cleaner on a daily basis. I have felt similar symptoms to those, thankfully none of the more serious ones...and I thought it was going to be about not wearing your wedding ring while welding.
1badSS
01-10-2012, 12:10 PM
Wow! Thanks for posting that.
Gordon0652
01-10-2012, 01:21 PM
Wow... i've always used brake cleaner..... Thank You
MrElectric03
01-10-2012, 01:23 PM
The brake clean we use and is probably found in most of California doesn't have the tetrachloroethylene in it(also says non-chlorinated on front) but the electrical parts cleaner we use does have it, so be careful of not only brake cleaner but others as well.
krissoto
01-10-2012, 01:24 PM
very informative, thx and will be sharing.
PH3NOM3NON03
01-13-2012, 10:13 PM
Thanks for posting that I'll definitely be more careful when i do the same on some welding jobs, normally i use the same chemical then wipe the area off with a rag but I think I'll try and stick to the wire brush and find a better solution for the same things reasoning of using them. Definitely printing this and hanging it in the shop!
MK3_TJ
01-13-2012, 10:28 PM
Will definitely pay more attention to the labels on stuff.
UMD_Jesse
01-19-2012, 11:22 AM
Holy crap....this should be stickied
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
