Hellraiser is looking for answers
Old 01-08-2012, 05:34 PM
formerly Chris p 02 (11-04-2011)
Hellraiser#1's Avatar
Default Hellraiser is looking for answers
did a leak down and a compression test on my motor because someone said I have a #3 cylinder low and out of spec.
leak down test and compression test
#1 100/90 cold 100/90 hot 190 psi cold
#2 100/88 cold 100/92 hot 200 psi cold
#3 100/88 cold 100/85 hot 200 psi cold
#4 100/83 cold 100/85 hot 200 psi cold
#5 100/87 cold 100/86 hot 200 psi cold
#6 100/88 cold 100/86 hot 200 psi cold
#7 100/85 cold 100/84 hot 200 psi cold
#8 100/87 cold 100/86 hot 200 psi cold
when the motor temp was hot I could hear air puching out of the air intake on every cylinder leak down test. this is a 440 built for dope ring gaps .024/.029 thanks for the help. Is there other things I could check!
Old 01-08-2012, 05:53 PM
Pwebbz28's Avatar
Looks good to me. Is it down on power?
Old 01-08-2012, 06:01 PM
I had my stock TB/PP and LPE CAI/MA 101 changed to a NW 102 TB and a 103 CAI/MA and lost 20-25 hp on the motor dyno from the last time she was in the shop!
Old 01-08-2012, 06:11 PM
Pwebbz28's Avatar
You make sure the tb isn't closing during a pull?
Old 01-08-2012, 06:15 PM
might need to put it back the way that it was and try that. I don't think that was checked. Ill ask when I talk to them monday! why would I hear more air push back when valves were closed when hot on the intake side? Did not hear it when the motor was cold
Old 01-08-2012, 09:01 PM
SouthTexasBully's Avatar
Call Mike sissy
Old 01-09-2012, 10:19 AM
Originally Posted by SouthTexasBully
Call Mike sissy
talked to Mike and they are going to check it out!
Old 01-09-2012, 11:37 AM
U dont have to act like ur motor is hurt just to avoid getting rolled up by Kevin! Haha jk sissy
Im sure everything will be just fine.
Old 01-10-2012, 12:00 PM
Hellraiser don't run from NO ONE YOU SISSY J/F/S/S
Old 01-10-2012, 03:42 PM
x TX OuTLawZ x's Avatar
Lol hope u fix it
Old 01-11-2012, 04:09 PM
just did another leak down after reading on the net. The leak down tester I have said to do it with the piston at the bottom of the cylinder and that's where the first numbers came from. After reading and talking to others I was told to check it a TDC at run temp. I did this and here are the new numbers? What do you think?
#1 100/91.5
#2 100/85
#3 100/82
#4 100/82
#5 100/92
#6 100/86
#7 100/81
#8 100/87
Old 01-11-2012, 04:59 PM
Pwebbz28's Avatar
I still don't see anything wrong. Have you put the old tb back on yet?
Old 01-15-2012, 10:04 AM
I need to get the slave cylinder fixed. If there is a problem with the motor no need in fixing the slave cylinder if the motor needs to come out. I was going to drop her off at the shop Friday but got called out to work! Maybe I can get her there this Friday!
Old 01-15-2012, 01:49 PM
INVISIBLEZ's Avatar
Get that hooptie running.
