Stock Fuel Pressure???
Old 01-08-2012, 07:52 PM
DOG-TWO's Avatar
Default Stock Fuel Pressure???
Can somebody tell me what the fuel pressure should be on my stock 98 TA? Thanks.
Old 01-08-2012, 07:58 PM
TransAmWS.6's Avatar
With the stock regulator, I believe it's 57-58psi and it drops like ten PSI or so when under load, someone correct me if I'm wrong though.
Old 01-08-2012, 11:17 PM
01ssreda4's Avatar
About 58 psi, and I'm pretty sure it should NOT drop at any time while the engine is running.
Old 01-08-2012, 11:19 PM
flippincamaro's Avatar
Yea it should never drop, if it does it isnt getting enough fuel, A=fuel filter stopped up
B= Fuel pump is getting weak C= losing voltage
Old 01-09-2012, 06:58 PM
DOG-TWO's Avatar
Okay thanks!
Old 01-10-2012, 12:04 AM
00pooterSS's Avatar
It shouldn't drop. In fact if it did anything it should raise, but that is on cars that use a vacuum fuel pressure regulators. We don't have those on ours. Just some worthless info to throw out there
Old 01-10-2012, 12:15 AM
Thule's Avatar
mine was just under 60psi w/stock pump, raised a little w/racetronix
Quick Reply: Stock Fuel Pressure???
