Does lowering car hurt e/t's??
Old 03-16-2004, 10:02 PM
DANS LS1's Avatar
Default Does lowering car hurt e/t's??
I'm thinking of doing a 1.5 drop but would like to know if it will hurt your et's or not. Thanks.
Old 03-17-2004, 12:34 AM
Bad Blu Formula's Avatar
It will hurt your 60' which later hurts your ET. If you do the process correctly by getting all the right parts, you'll be fine.
Old 03-17-2004, 06:21 AM
Fast SS on TNT's Avatar
Don't lower your car. You will kill your weight transfer.
Old 03-17-2004, 08:46 AM
5POINT7's Avatar
You can lower your car. The difference will be marginal. It really improves the look.
Old 03-17-2004, 08:58 AM
YOUR03COBRA8ME's Avatar
When i lowered my car i started run way better for some reason i used eibach coil-overs (Adjustable)with there drag spring in the rear really soft spring Im probrbly one of the lowest cars on this board Tucken the 18's
Old 03-17-2004, 04:54 PM
kbronSS's Avatar
i was also thinking the same thing.....i was going with 18" smoothies 2 with 555r's and the prokit. But now im not sure Now im thinking of staying with the stock suspension and going with zr1's.
DECISIONS DECISIONS.....now im back to square one and not sure what to do at all. Maybe go ahead with everything without the dr's and put the dr's on my stock wheels. But now we are back again about the suspension.??????????????????????????????????????? ???????So it wont hurt ET by much right?
Quick Reply: Does lowering car hurt e/t's??
