Dynamometer Results & Comparisons - Pleased With My H/C Combo!
strokerrace
01-09-2012, 05:04 PM
2000 Trans Am LS1 90k
-228R
-PRC Stg 2.5 5.3 milled to 59cc chambers
-PRC Dual Spring Kit
-LS6 Ported Oil Pump
-BRP pickup tube girdle
-COMP Magnum 7.4 pushrods
-GM mls head gaskets
-GM head bolts
-LS7 lifters
-LS2 lifter trays
-New Waterpump
-New Alternator
-Repacked all pulleys
-New Belts
-160 Thermostat
-All new gaskets everywhere
-ARP Flywheel Bolts
-LS6 intake
-Ported Tb
-LS6 Valley Cover
-LS6 Steam Tubes
-All new Sensors on motor
-Greentop 42# injectors w new orings
-Tr55s
-Taylor 8.5s
-Pacesetter 1 3/4 w gm gaskets
-Moser 9" 3.50 gears
-Texas Drivetrain T56 Stage 2 Trans
-Diamond Stage 2 Clutch Kit
etc...
Heres the Numbers!
RWHP: 443.93
RWTQ: 409.36
Graph:
http://i85.photobucket.com/albums/k56/ibanez1990/402643_10150455106402531_653817530_9221537_5898289 57_n.jpg
navyblueSS
01-09-2012, 05:20 PM
Nice numbers!
msydow
01-09-2012, 05:22 PM
pretty flat torque curve there. numbers dont mean too much. whats the butt dyno say?
john563
01-09-2012, 05:25 PM
small cam and 9 inch to boot..I have these same heads in an A4..I been very happy with mine :)
strokerrace
01-09-2012, 07:11 PM
Well coming from a stock internal full bolt on car it definitely has some punch. Your right though, the torque doesnt hit as hard as I expected but its smooth power all the way through. I was also on 19" C6 wheels and was using my hooker catback if anybody cares to know..
JRENIGAR
01-09-2012, 07:30 PM
Same dyno I had mine tuned on to make #'s in sig. Nice place. Lets get together and see how they do sometime...
Johnnystock
01-10-2012, 02:07 PM
Sounds like a bit generous dyno for LS6 intake, 9inch, Pacesetter(ORY ??). Not hating, just saying ;)
..anyway, looks like a very nice street setup, congrats!!
JRENIGAR
01-10-2012, 02:32 PM
Well, for reference they told me a bolt on ls1 with an auto usually makes 310-320 on their dyno, so???
Johnnystock
01-10-2012, 03:03 PM
Either its a really strong runner for what it is or a bit generous dyno. Not impossible by any case, thats not what I think BTW. For reference, I make 404rwhp and trap 117 ;)
strokerrace
01-10-2012, 03:53 PM
JRENIGAR-
Cant see your sig info on my phone but whats your setup? Im pretty pleased with the tune so far, just gotta button up some other things since I made the swap and then see how it handles abuse.
strokerrace
01-10-2012, 04:00 PM
Johnnystock, yes it may seem a little high but this motor still has the factory cross hatchings on the cylinder walls and has no signs of anything wrong with it/abnormal wear so far. Texas Speed said to expect anywhere from 420-430 at the least with this combo and it did just that and a little more! It definitely is a strong runner and it actually pulled close to those peak numbers on 3-4 dyno runs. It was a Dynojet so you know how those usually dyno higher...
JRENIGAR
01-10-2012, 04:54 PM
JRENIGAR-
Stock engine,a4 trans, and 10 bolt 3.23 gear all with 190k on it, hooker lt's, tsp oryp, hooker catback, ls6 intake, ported stock tb, intercooled vortech v9-g trim with 8.5-9lbs@ 6000 rpm where it shifts @. Made 450/438 earlier this summer @ Dyno Speed. My car is close to 3900# with me in it because of extra shit like subwoofer box and 2 12in memphis subs and a big memphis amp. I also have heavy ass UMI weld in subframes and rear boxed control arms with poly bushings. 17in staggered ZR1's with 315 sumitomos that are heavier than the 16 in stockers. Glove box and console full of crap too. It ran 12.08 @ 117mph with 1.95 60ft @ Motorsports park last october. That same night there were a couple of 6 speed ls2 vettes with full exhaust and intakes running 12.5's @ 117-118mph with 60ft's almost identical to mine. If I can, I will try to post the dyno graph later this week, maybe...
JRENIGAR
01-10-2012, 04:56 PM
What was the race weight, 60ft, and da?
strokerrace
01-10-2012, 06:18 PM
Wow. Have you had any issues with the tune? And hows driveability? Just curious... Feel free to PM me if you want to discuss in private..
JRENIGAR
01-10-2012, 07:12 PM
It drives perfect and still gets the same 21mpg it got when it was bone stock. It does, however, have some sort of hiccup when idling. It sometimes studders a lil bit almost like a 224r cam or something till I tap the gas or it just quits on its own after about 10 sec or so. I ask about getting it SD tuned and they kinda shyed me away from that saying it wasnt necessary at my power level and the stock maf would be fine, although, I have heard it will make a pound or two more boost without it. I have HP Tuners but wouldnt know how to do it unless someone told me and I dont wanna pay to have it tuned again. Its barely loud enough to hear in or outside the car at about 700-800 rpm's it has a slight whistle almost like the prochargers do. Im probably just gonna get a meth kit and see if that helps enough to stay away from no2 and just drive it. Josh says meth should get about 50-75rwhp more and if so that will just have to do. I dont beat on it everyday but I do have fun with it from time to time. It was tuned to be safe at 11.3-11.5 afr and about 12 deg timing wot. The iat's usually run about 11-15 deg above ambient. Usually a run from 50-120 or so makes it rise from say about 70 deg to 110-115deg just to give others an idea of how efficient or not the system is. If I ever get another engine I would like ls6 heads and cam, if that netted another 30-50 rwhp Id be thrilled. Im really not sure if the iron 6.0 or another ls1 would be better because of the 70 or so lbs this kit weighs. I dont want a really nose heavy dd car so aluminum might be my only option...
Ws6Dnero
01-11-2012, 08:59 PM
Hey man what color is your trans am? do you be out on summer?
Ws6Dnero
01-11-2012, 09:00 PM
oh an @Jrenigar would you happen to know a guy name mario that works at oreilly??
strokerrace
01-11-2012, 10:32 PM
Silver with silver c6 wheels. Yea I drive on summer almost everyday ha
strokerrace
01-11-2012, 10:34 PM
Glad to hear your tunes good as well. Looks like a nice DD from the results in your thread. Come on over to memphis sometime and lets go to the track. I havnt even been yet with the TA but plan on it when it opens back up this season.
Johnnystock
01-12-2012, 01:46 PM
2.2 60ft LOL 3.42 gear, race weight is 3650, ds, not sure 485 above see level??
Jason 98 TA
01-12-2012, 05:31 PM
Great results with the PRC Stage 2.5 5.3l heads!!
strokerrace
01-12-2012, 05:38 PM
^ Yea thanks to you all over Texas Speed!
Sales2@Texas-speed
01-13-2012, 10:42 AM
Nice numbers! There are a few combos on the front page of this dyno section currently with more camshaft, more money in heads, etc that are falling a good bit short of your combo! :drive:
Have fun and be safe!
redtail2426
01-14-2012, 12:57 PM
i really like your setup,but the first thing i would do is change out those gears for some 4.10s'
strokerrace
01-14-2012, 07:31 PM
Yea I plan on doing a gear change when I recoupe from the cash I just spent. Got some other things to work out too that take priority to performance mods.
JRENIGAR
01-15-2012, 01:33 PM
oh an @Jrenigar would you happen to know a guy name mario that works at oreilly?? Dont think so, might if I seen him though...
JRENIGAR
01-15-2012, 01:35 PM
Glad to hear your tunes good as well. Looks like a nice DD from the results in your thread. Come on over to memphis sometime and lets go to the track. I havnt even been yet with the TA but plan on it when it opens back up this season. Will do, do you know when it opens again?
strokerrace
01-15-2012, 02:31 PM
Not sure but its a ways off I think.
yonerhottlt1
01-15-2012, 10:07 PM
Nice numbers, that setup is working very well. Another example of why you don't need a donkey dick cam to make good power.
JRENIGAR
01-16-2012, 10:09 AM
Till then, I would be up for a lil roll race to see how they do and kinda factor out who can hook better till the track opens if your up for it. I think it would be a fair race and would kinda tell the diff between how and where the power and torque kicks in between the two setups. It might kinda help others that are getting ready to make some purchases in the near future too... I had an 03 cobra that had a different upper pulley a cold air kit and a tune. I would love to run another one that was similarly modded just to see how I do If you know of any around here. I sold mine to a younger guy in Olive Branch, MS and havent heard from him since then or Id try to run it.
garygnu
01-16-2012, 11:11 AM
great numbers ! check your IAC to see if it clean and not sticking at times.
strokerrace
01-16-2012, 11:32 AM
Thanks for the compliments guys.
Jrenigar- Wouldnt mind racing you but theres not really many places that arent gonna have cops around and its just not worth the risk to me of hurting myself/others on the street or getting my car impounded. Maybe if it was down at rivergate or something when its day light out. The tracks a different story though!
JRENIGAR
01-16-2012, 11:53 AM
fair enough.
camaro98z28
01-16-2012, 12:28 PM
Thats about 40+ hp lowWell, for reference they told me a bolt on ls1 with an auto usually makes 310-320 on their dyno, so???
JRENIGAR
01-16-2012, 01:23 PM
Thats a good thing for me, I would like to get it checked somewhere else in the Memphis area just for comparisons sake but I dont know of another dyno shop.
