Cam suggestions.
Cam suggestions.
Hey everyone, I'm currently running the hotcam & was wandering if there was a better performing cam other than the LS6 that will work with the LS6 springs & that will also work well with a set of low budget ported heads(280int/210exh @ 600 lift using stock valves). This is also my daily driver.
TIA,
Mike.
TIA,
Mike.
Originally Posted by 2xLS1
You are really limiting your cam choices by sticking with those springs.
thanks,
Mike.
SN95 Director
but i agree with you anyway, the ls6 springs are limiting. if it were me i'd pick up some 918's or manleys and run and tr224, or FMS FM4 or FM10
For sure. The HotCam, sounds Hot. The Durration is okay, but the lift sucks.. And by the way I have one too... Okay. Go with the Comp Cams 918 springs. 224/224 .560 .560 and a 112LSA. This will provide good gains over the Hotcam..
Or you could step up to the new Thunderracing cam. that pushs out 450 RWHP on stock heads and all the bolt on's
Good luck
Clint
Good luck
Clint
I have the comp 918's, stock retainers, 7.4 chromoly pushrods with stock heads and a MTI C1 cam ( 222/222-.566/.566-112) and have had no problems with this setup after 10000 miles. Get some better springs and it will give you better options as far as cams go
SN95 Director
Originally Posted by MM98
What about the Lunati 222/230 534/544 112lsa?? Do you think some decent gains would be made with this over the Hotcam? Just trying to get some ideas.
Thanks again guys,
Mike
Thanks again guys,
Mike
i say dump the ls6 springs, pick up some that are rated to .600 and then spend some time researching and find the cam that meets your needs and requirements.
One of these days he'll start listening to me.
Thanks for the help guys!!!!
Mike
