clutch help
clutch help
Ok guys so i have a couple questions? I have an 2002 Formula Firehawk its a 6 speed an my question is when going to reverse i have to really push it hard an i know that can't b right an sometimes in the gears it grinds! Any suggestions what to do or where to take it an not kill my wallet? I live in La Porte thanks
Its something fishy going on bc sometimes it goes in without any grinding at all im not sure at all!? Anyone know of a reputable mechanic or shop to fix this
It more than likely was something to do with the clutch when it comes to reverse. First and reverse are usually the tell tell signs that it is something with the clutch. If you dont have the money yet, try flushing the fluid and see if that helps. There is plenty of howtos that show you what to do. Now the grinding could be a couple things. Could also be the clutch. Pressure plate might be being lazy or it could be an internal issue with the trans. To help get it around now. Try pushing the clutch pedal a couple times and try to go into reverse. Also you can push the clutch pedal in and hold it in and then go third to reverse. It slows the internals down and makes it easier to go into gear.
