Pontiac GTO 2004-2006 - Does any one knows...
CAMSTER
01-10-2012, 02:01 AM
Any one makes a custom engine cradle or 8 frame for our 04/06 gto?
mark21742
01-11-2012, 08:37 AM
Really no need for it.....I was shocked by how light that big peice of metal actually is.
black00TA
01-11-2012, 11:26 AM
the front end is a heavy beast, ditch the skid plate and that will save a bit
mark21742
01-11-2012, 01:36 PM
The big problem when it comes to losing weight off the GTO is most of the weight is in the sheetmetal itself....I just cut the rear floor/ frame/ wheel wells out of of my 04 and was shocked at how much the floor and sheetmetal framerails weighed....I'm sure this is the same for the front too. I've had the whole cradle and front suspension out of mine a few times and none of yhe parts them selves ate all that overly heavy, so that just leaves the body shell and sheetmetal framework.
How far do you want to go to lighten your car? I should be atleast another 100 lbs lighter after my 9" solid axle, 4link and back half swap!
my first GTO
01-11-2012, 03:03 PM
Stay tuned I do know of something in the works very soon.....
kjhallex
01-11-2012, 04:50 PM
Keep us updated!
magnum-gto
01-12-2012, 01:48 PM
Yes.....I invested about an hour last night to the project.:)
my first GTO
01-12-2012, 03:46 PM
Jan, as I see Tony did as well.....Jan can you call me with your shipping address when you can....Thanks
CAMSTER
01-12-2012, 04:29 PM
Keep us updated!
PM me asa you know...
CAMSTER
01-12-2012, 04:57 PM
I want to remove 300 pounds, even after the roll bars, but the great deal of goodness is added to a car when is made easy to work on, and have room around the engine, on my engine craddle, i made it with removable center brace, so i can remove it for bearing or any other inspection, with out having to lift the engine or lower the frame.
I have removed; the belly pan, will change seats for racing light weight pair, with the roll-bars can take out the gas tank brace/ gone is the hitch reciver, the drag pack does remove 77 pounds, another info i want is for lexan windows, anyone knows connection, pls post it, thanks.
I did get a big set back with the lsx block, as far as weight
CAMSTER
01-12-2012, 05:08 PM
Will you pls post some pix of the back of your car, i assume you have some wide tires and wheel set in there, i have always like to see more tire tours the inner side of the back of the gto, with some good size dich on the wheeels, thanks.
I had a reasonable suspition that the gross over weight in our cars, was due to the unitise body, itself..You confirm this..
mark21742
01-13-2012, 05:20 AM
I already had the wide body, but had to adjust the body roll for the new wheels and tires.....18" wide 15's, and for now 31-18.50 15's till I wear these tires down then going with 33-22.50 15's
http://i283.photobucket.com/albums/kk300/mark21742/IMAG0667.jpg
Still need to cut and raise the tunnel and build the cage...main hoop should be here beginning of next week
http://i283.photobucket.com/albums/kk300/mark21742/IMAG0694-1.jpg
Money shot!
http://i283.photobucket.com/albums/kk300/mark21742/IMAG0659.jpg
CAMSTER
01-13-2012, 01:23 PM
Thanks for shearing those pix, looks like a lot of fab/hard work, but the massive tires, man thats awsome... subscribing to more info and pix as you progress... thanks again, David... PS, You may end up with record setting wheelies for a late gto...imo..
mark21742
01-13-2012, 01:29 PM
I'd LOVE to do I wheelie :)
my first GTO
01-13-2012, 05:38 PM
To big for me....
mark21742
01-13-2012, 08:57 PM
Hey Frank. What was your race weight and HP this past season?
I love your car :)
my first GTO
01-13-2012, 11:17 PM
3595 and 1,056 to the wheels at 8.99@154
