misfire after head swap
my car has stock tune and now has longtubes ORY and catback. put some ported 243's on and i am getting a misfire in cylinder 5. could all this air flowing through on stock tune cause a misfire?
I plugged my diagnostic obd2 scanner in, and i had cylinder 8 out..
just replaced the sparg plug and it was fixed..
the plug might of got damaged during the swap or if you reused them it might of fouled out..
I had a miss fire code after my engine swap. Turned out to be two things: I has damaged the map sensor pig tail, and the intake rocker arm on number 4 had come off and was laying there next to the pedestal
