Do tuners block the PCM so you can't read anything from it?
Old 01-10-2012, 07:58 PM
Rob94hawk's Avatar
Default Do tuners block the PCM so you can't read anything from it?
My hawk crapped out today. SES light is on and no one can read the PCM through the port under the dash. Had it tuned at Kaltech and wasn't able to get in touch with anyone there today so I was wondering if it was the norm for tuners to **** block any scanners from reading the SES codes.
Old 01-10-2012, 09:40 PM
gunin4cer's Avatar
Yes, They do it all the time and now your held hostage....
Old 01-10-2012, 09:53 PM
salemetro's Avatar
That's a first for me....you're saying that you can't retrieve any dtc's? I've never heard of a tuner locking out the ability to read dtc codes....tune files get locked fairly often though. Usually (but not always) to hide crappy work, from posts I've read elsewhere.
Old 01-10-2012, 09:58 PM
lethal bird's Avatar
I know of a few that will lock you out.
Old 01-10-2012, 10:04 PM
salemetro's Avatar
Yep...me too...usually on "exotic" tunes where a lot of work and time was put into the tune. Other than that, most good tuners don't usually worry about it. That's just been my personal experience though.
But are you meaning they lock the ability to retrieve trouble codes?
Old 01-10-2012, 10:07 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Yes but I paid for that work and time.
Old 01-10-2012, 10:11 PM
salemetro's Avatar
I'm right there with ya,man.......but I can also understand a tuner not wanting to share any "secrets " with other people, should you decide to post your custom tune online somewhere.
Old 01-11-2012, 06:11 AM
edcmat-l1's Avatar
"Locking" a tune does not prevent you from reading codes, or scanning data. That's a totally different problem.
Locking a tune only prevents you from downloading (reading) the tune, and opening it.
Old 01-11-2012, 06:16 AM
Rob94hawk's Avatar
That is correct. My mechanic cannot read the pcm via the port under the dash.
Old 01-11-2012, 06:31 AM
Sarg's Avatar
Never heard of being locked out of trouble codes. Might be something going on with wiring.
Old 01-11-2012, 08:22 AM
keliente's Avatar
The cigarette lighter fuse is probably blown. Check your fuses. If the DLC isn't getting power then you won't be able to read the codes.
Old 01-11-2012, 08:39 AM
Rob94hawk's Avatar
I have an LT1 based car. Is the LS1 and LT1 DLC the same?
Scratch that. There's power to the lighter fuse. Damn strange.
Old 01-11-2012, 01:38 PM
Moderator
jimmyblue's Avatar
I thought the OBD-I LT1s were PROM cars and only the
OBD-II were read / writable? Didn't OBD-II roll on later
than '94?
Old 01-11-2012, 01:42 PM
edcmat-l1's Avatar
than '94?
The 93s were PROM cars. 94, 95 were read/write (EEPROM) but still OBD1, although the 95 had an OBD2 connector. OBD2 became implemented in 96. Kind of a confusing time period it was LOL
Old 01-11-2012, 10:29 PM
2TR
2TR's Avatar
Locking a tune can't block out OBDII scanning. Have you tried a different Vatozone from the original one you requested to scan your car? User error?
Old 01-12-2012, 07:20 AM
edcmat-l1's Avatar
It's not OBD2, it's OBD1.
Old 01-14-2012, 03:13 AM
01WS6/tamu's Avatar
The computer died and it lost serial communications with the DLC. Unless there is a blown fuse etc for the PCM preventing it from powering up.
