Trick Flow pushrods and Patriot Gold Extreme Valve springs....Good?
Old 01-11-2012, 04:17 PM
streetknight2's Avatar
Default Trick Flow pushrods and Patriot Gold Extreme Valve springs....Good?
Patrick G spec'd me a cam for my LS3 head LQ9. He recommended 7.400" push rods and TEA .660" lift valve springs or equivalent.
I don't see a .660" spring on TEA's site. I found the Patriot's on Jegs. Will these work?
Also, I notice the Trick Flow push rods are a good bit cheaper than say Comp's. Will they work ok or do I need to look farther?
Old 01-11-2012, 04:26 PM
JPH
JPH's Avatar
TEA= total engine air flow
7.400 should be fine for your application if ALL is stock besides just the cam. 5/16", .080 wall 1pc. c/m pushrod should be fine.
Old 01-11-2012, 04:34 PM
The engine is a stock lq4 with ls2 pistons and rods, stock LS3 heads milled .030" and a cam. Using carb and was told by Patrick G to plan on shifting approx 6800 RPM
Old 01-11-2012, 04:37 PM
JPH
JPH's Avatar
Pat might be reffering to part number TEA #CCA-26921-KIT.
Old 01-11-2012, 04:54 PM
wildcamaro's Avatar
Yep patriot golds will do the trick, or grab some comp 921s
Old 01-11-2012, 05:54 PM
985136's Avatar
Trick Flow pushrods are cheap china made garbage.I've had the tip of a trick flow pushrod tip break off(they are really two piece pushrods).It was these http://www.trickflow.com/partdetail....0&autoview=sku That's why the price is lower.Comp cams pushrods are better.
Old 01-11-2012, 06:02 PM
JPH
JPH's Avatar
Cool. Should run strong.
