Turbo wot pulls with hptuners...log and tune inside
Just wanting some other more seasoned eyes to make sure im goin in the right direction. Im commanding 11.4 during wot for the boost. Ive done a few lower gear pulls with no prob but had to back out during 3 and 4th gear runs because the afr started rising. The enclosed tune is after the log....all i changed was increase the 100-105 kpa row in the ve and secondary ve to try and compensate for the leaning out. I know the table is spikey on top but im more concerned with hitting my afr target before i do alot of smoothing. stock heads, manifolds and cam. running trick flow 48lb injectors with 68-70 lbs at the rail and an aeromotive stealth intank pump. around 5-6 lbs max boost right now tr6 plugs. msd wires. thanks for taking the time to look at this. i do know that the timing is conservative as well. still getting some kr...but i think this is from the choppy ve?
Brandon
Brandon
