317 heads with an L92 Cam.
Old 01-11-2012, 06:18 PM
stavman's Avatar
Default 317 heads with an L92 Cam.
I have an LQ4 and was going to go with a the Livernois Stage 2R MAX L92 camshaft. I have the 317 heads, going to run LS9 head gaskets.
Fits: N/A L92/L76 engines. Also suitable for N/A LS1, LS2, LS6 engines with factory unported cylinder heads! Will work in engines with factory pistons, but may require flycutting.
Will i have any problems running this cam? Has anyone Ran an L92 cam in an non-L92 setup with results?
Old 01-11-2012, 09:46 PM
garygnu's Avatar
a l92 cam is designed to work best with a l92 head flow %.get a cam the best work with the 317 port flows.
Old 01-11-2012, 10:12 PM
stavman's Avatar
Ok, well i don't want a custom cam, i'm just looking for something I can buy. I don't care if its streetable, its not a DD. I have a 4k stall, LS6 Intake, Headers, etc etc.
I can't get a good answer. There are SO many cam choices.
Old 01-11-2012, 10:30 PM
wildcamaro's Avatar
if you already have a 4k stall then i would be gettin a top end cam with crazy high hp numbers with operating range of like 3500-4000 rpms to 6500+ rpms...thats like ms3 ms4 territory
