K-member for turbo.. can UMI k be used?
i know BMR makes a specific TURBO K-MEMBER
but i want to stick with UMI since all my suspension thus far is UMI (i know.. i know.. its just a preference)
Does any one have a Truck Turbo or any turbo kit with the UMI unit?
LS1Tech Premium Sponsor
It really depends on what size down pipe you want to use on your set up. We have gotten as big as 5" down pipe to work with our turbo k-members. Our BMR turbo k-members will give you more clearance and free up a few pounds off the front of the car. If you have nay questions I can help you out with let me know.
Thanks,
Kyle
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Here are a couple pictures of the two k-members to show the differences between the two.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Those pictures do a good job of showing the difference in clearance.
However just a note on picture #2, because of our tube design our k-member sits higher when on a surface. To get an accurate comparison the BMR k-member in front would need lifted about 1-1/2" for a more accurate comparison.
Just a little nit-picking on my end
Thx guys
really appreciate it
im gathering parts for a truck manifold TT set up and want to run 3" down pipes through each side of the motor through the k
if that makes sense lol
The strength between our normal BMR k-member and our turbo k-member are pretty much identical. You won't have any issues using a turbo k-member for doing some road course and other handling oriented driving.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
We do know the APS kit works with our K-member. If you are running a single turbo there is no issue and twin will work as well. The turbo k-members offer more room for larger downpipes. But we have seen a lot of APS systems with our k-member.
I hope that helps!
Ryan
I hope that helps!
Ryan
I have the APS kit with UMI's k-member. It works so damn well that I can't wait to sell it to some other poor sucker and get BMR's. I'm sick of my intakes sucking shut!!! And no matter what, UMI refuses to create something similar to the "BMR-APS" hybrid K-member. I shouldn't have to beg, you know?
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
