Ported vs. Regular Oil Pump
I know you can pick up the ported version for 120 or the regular version at GM Parts Direct for 56, is there a need for the ported version on a H/C setup?
LS1TECH Sponsor
i would say either a stock ls6 or ported ls6 pump both should get ride of the inherent problems of your stock 98 pump if in fact you are replacing it...personally Im not even gonna bother I figure my motor will be on borrowed time anywayz might as well go out in style lol
I plan on going with a new LS6 oil pump on my next engine project, I don't think a ported one is necessary. If you want one and fell better about it go for it. I've never regretted going with a Katech ported LS1 oil pump on my 99 T/A that had less than ~35,000 at time of H & C.
If your 98 has a lot's of miles(35,000+) on it it's probably out of the "danger zone".
Originally Posted by BoneSS
I just turned 27000, so I will get one or the other. Anymore opinions?
It was in the 60 dollar range. If it is good enough for a z06 I felt it was going to be ok for me.
