408 hke boost engine complete and 1000up fuel system
Category: Accessories
Price: $6500
Part Fits: 93-02 Chevrolet Camaro, Corvette
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Quick list of whats in this motor. It was built to hold 1000+hp and is very solid.
Engine components:
New 6.0 Block
Scat 4340 LS1 4.000 crank 24 tooth reluctor
Eagle LS1 H-Beam Rods 6.125 Long
Wiseco K396F3 LS1 32cc Pistons 4.030 Bore
1/16,1/16,3.0mm Rings 1.115 Comp. Height
Wiseco Custom Pins 9310 Tool Steel .200 wall 100.00 100.00T
Speed Pro Hell-Fire Rings #R1910035 1/16,1/16,3/16
4.035 bore Power Adder - 1000 RWHP
Federal Mogul 152M1X 3/4 Groove Main Bearings for LS1 Coated
ACL CB 663 H Rod Bearings for 2.100 SBC Chamfered Race Bearings Coated
ARP 234-5608 ARP 234-5608 Main Studs
GM Engine Block Plugs
Custom HKE Cam 236 / 236 115+3
ARP 134-1003 ARP 134-1003 Cam Bolts for LS1
GM 1258-901... GM 1258-9016 LS1 Cam Plate
ARP 134-1002 ARP 134-1002 Cam Retainer Plate Bolts for LS1
N-Motion LS2... N-Motion LS1 Double Roller Timing Chain
GM 1249-922... GM 1249-9225 LS7 HR Lifters
TFS 5/16 Pus... TFS 5/16 Pushrods[/COLOR][/COLOR][/COLOR]Stage 3 Ported and polished 317
Patriot X-Tre... Patriot X-Treme Gold Spring Package for LS1s
Ferrea LS1 Super Alloy replacement exhaust valves F1894P (1.550 Diameter?)
ARP 234-4317 Head Studs for LS1 (new style 6.0 block with equal head stud length)
GM 6.2 MLS ... GM 6.2 MLS Head Gaskets
The sale of the complete motor will inclued the follwoing. I'll put prices next to each item just in case I start parting it out.
Edelbrock pro-flow intake with edelbrock rails $475.00
FIC Bosch 95# at 58psi injectors with pig tails $475
95mm throttle body $245
Stage 3 ported and poslished 317 heads complete with patriot gold dual valve springs, titaniam retainers and Ferrea supper alloy exhaust vavles $975
1000hp fuel system Lonnies performance
$1150
Includes the following
Dual walbro 255 fuel pump
Magna fuel inline filter -8
Magna fuel regulator with gauge -8 feed -6 return
-8 feed lines with an fittings on all the ends
-6 return line with an fittings on all the ends
Racetronix wiring harness with hobbs switch harness and hobs switch.
