Pontiac GTO 2004-2006 - Black fluid on the rear tires
TheMayneEvent22
01-12-2012, 09:12 PM
I noticed that my back rims were getting dirty very fast. I looked under the car yesterday and saw black fluid running down my exhaust pipes and spraying out on the rims. The fluid is coming from right above the joint where the driveshaft and the diff. meet. The bottom of the car (right about this joint and above the diff) is soaked. The bottom of the diff is dry and clean. I can not tell where it is coming from. Exhaust leak? Bad seal on the Diff? Any help would be much appreciated. I have an 05' manual.
02ws.sik
01-12-2012, 09:20 PM
Ok let lmao for a while. Exhaust leak??? What do you think comes out of the exhaust? It is going to be a bad seal or something in the diff. Its not runnimg down the drive shaft to the diff is it?
TheMayneEvent22
01-12-2012, 09:48 PM
Possibly moister and carbon mixing and leaking out...just thought it was an option. No, there is no trail of fluid going down the drive shaft. Just fluid all over the bottom of the car and all over the exhaust pipes. If it is the seal, how hard will it be to fix?
402GOAT
01-13-2012, 09:00 AM
sounds like the pinion seal possibly
redtan
01-13-2012, 09:13 AM
If it's a fluid, most likely coming from the diff.
And if it's black, most likely you need to change your diff fluid.
ShoddyHog
01-13-2012, 11:24 AM
Pinion seal.
TheMayneEvent22
01-13-2012, 12:59 PM
Is it a hard/expensive fix?
02ws.sik
01-13-2012, 03:51 PM
Its going to be a pita you can buy a rebuild kit from texas speed.
svede1212
01-13-2012, 04:21 PM
Yup, fairly common
scphilli
01-15-2012, 02:06 PM
Touch it and smell your finger!!!!! There will be no mistaking it if it is from your rear diff. Smells terrible
ULTIMATEORANGESS
01-15-2012, 02:24 PM
most likely something leaking. i have two rear seal leaks fixed under warranty.
my first GTO
01-15-2012, 03:06 PM
It could be a CV Joint boot leaking and The Grease slinging on your Wheel....
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
