Best aftermarket heads for a 5.3?
Old 01-12-2012, 11:33 PM
flynbludream's Avatar
Default Best aftermarket heads for a 5.3?
Like the title says, what is the best thick deck aftermarket head for a 5.3 bore size? I would assume you would get into shrouding issues if you went too big. Lets hear some thoughts.
Old 01-13-2012, 07:04 PM
silver_82's Avatar
heard really good things about trick flows 205cc head on 5.3s. Look into that 1st
Old 01-14-2012, 07:33 PM
Bobsmyuncle's Avatar
I'm in for this... I would lik to see what these 5.3s can actually make in all out effort builds. The thick cylinder walls are heaven sent.
Old 01-14-2012, 08:30 PM
GarrettT/A's Avatar
Im gonna use the old prc terminators on a 4.8l. Seems like they should work well with the smallish 200cc intake runner. Unless valve shroud becomes an issue...., guess ill find out.
Old 01-15-2012, 08:33 PM
LS1LT1CAM's Avatar
trick flow 205's are going to go on my 5.3 that I will running in a real street class 76mm turbo
Old 01-16-2012, 06:33 AM
1fast bird's Avatar
As far as I know the only after market castings for the 5.3 are the TFS 205's.
Old 01-17-2012, 10:01 PM
Dave@WCCH's Avatar
Just to let you know we do a version of the Edelbrock head with a 200cc intake port that we made just for the 5.3.
It can also be upgraded later to the 215 or 245cc version if you end up building a larger motor.
Quick Reply: Best aftermarket heads for a 5.3?
