What happen to my 4L60e ?
Old 01-14-2012, 11:08 AM
s-10ls1's Avatar
Default What happen to my 4L60e ?
Well I went to Baytown last night and on my 3rd pass I heard a pop off the line. When I limped it down the track to get my time slip I notice I didn't have overdrive. I still have 1st,2nd, and 3rd but not overdrive. What do you guys think is wrong with my trans? Also it's a built trans from century
Old 01-14-2012, 09:58 PM
SixShooter1125's Avatar
Is it shifting 1-2-3 normal?
Old 01-15-2012, 12:04 AM
s-10ls1's Avatar
Yeah if I go through the gears manually but if I put it in overdrive it will just rev up
Old 01-15-2012, 09:53 AM
CHADsterss's Avatar
Time for a rebuild
Old 01-15-2012, 12:18 PM
dgcustomz's Avatar
I had this happen once. I was told it was a broken sprag. I have no clue if it was true.
Old 01-15-2012, 12:54 PM
5w20's Avatar
Normal 4l60 wear
Old 01-15-2012, 01:54 PM
I had a similar problem recently. I had to keep driving it without OD due to it being my DD. (15 mile commute)
I ended up losing 3rd eventually then went for a rebuild. Sprag was destroyed and the 3-4 accumulator spring broke. Not sure which went first. Futher inspection showed a cracked valve body and destroyed clutches and bands.
Needed a full rebuild.
Good luck to ya bro!
Old 01-15-2012, 02:02 PM
s-10ls1's Avatar
Thanks for the input guys. The trans is pretty new so I know it's not normal wear. I'll be calling century tomorrow to see what they have to say
Old 01-15-2012, 03:34 PM
5w20's Avatar
Lol
Be smart, already failed once. It's time to upgrade to a transmission that can hold. Normal busted up 4l60...
Old 01-17-2012, 01:10 AM
Luckymex_dallas's Avatar
thats how racing go
Old 01-17-2012, 01:17 AM
1990LSx's Avatar
4L80E and call it a day.
Old 01-17-2012, 09:54 AM
5w20's Avatar
