View Full Version : help me with fuel system
Fastdriver1992
01-14-2012, 06:10 PM
car is a 00 fbody already with a hotwire kit and racetronix pump. id like to build off what i have so its cheaper. car is 383 with d1sc ported trick flow 225, ls6 intake, brutespeed blower cam. should make 12 pounds and 16 when i up it. also have 80 pound injectors for it. should i add a kenne bell boost a pump and would the be sufficent? what else could i do? or would it be as simple as throing another 255 walbro in it
ZL1Killa
01-15-2012, 08:49 PM
i would either go dual walbros (255 pumps) or go with an external. Lonnies has a setup... Heintz Racing has a setup, I think also they make a 340 L/hr pump that you can put into the tank now
williamkeller23
01-18-2012, 12:32 AM
aeromotive makes the 340 lph
