4.8 with ms3 or????
Old 01-14-2012, 06:01 PM
831jd's Avatar
Default 4.8 with ms3 or????
I wanted to know if I would run into problems if I were to put a ms3 cam in a 4.8 with stock heads or what off the self cam is the biggest I can run looking for a all track car will be going into a 95 camaro thanks
Old 01-14-2012, 06:10 PM
zacht's Avatar
look at comp LSr cams for the 4.8-5.3 i dont think they require flycutting but they're also some all out performer cams...
https://ls1tech.com/forums/generatio...-grinds-3.html
not sure on the ms3 tho...not sure if anyone has done it
Old 01-14-2012, 06:12 PM
Latch's Avatar
Why such a big cam in a small motor?
Old 01-14-2012, 06:42 PM
831jd's Avatar
Just know the ms4 is great on ls1s just thought maybe the ms3 would work better since it has smaller cubes
Old 01-15-2012, 12:24 PM
zacht's Avatar
im going to have to disagree...
Old 01-15-2012, 02:12 PM
wildcamaro's Avatar
Yea I wouldn't run that in an all out track car in a 4.8, just because you can overcam it which will make it perform like ****
Old 01-15-2012, 02:14 PM
2002silverz28matt's Avatar
I wouldnt even consider putting that cam in a 4.8, it will be slow as hell until 5k rpm.
Old 01-15-2012, 02:53 PM
garygnu's Avatar
you want a cam that will work best with your gears and tranny combo.fill out a cam request at compcams ,and you will under stand ever thing involved in picking the best cam.a small cam is funner then over caming a engine.the 54-455-11 cam mite be a safe cam.
Old 01-15-2012, 03:54 PM
Blk98Vert's Avatar
My friend has the ms3 with a turbo in his 4.8. No way id run that cam na
Old 01-17-2012, 03:59 PM
831jd's Avatar
How about one that has 230/230 duration car has 3600 stall 3.42 gears and bolt ons
Old 01-17-2012, 04:04 PM
'02 WS6's Avatar
For the price of an MS3 cam kit you can buy a 5.3
Old 01-17-2012, 04:20 PM
DunnoWhoThisIs's Avatar
we put a xer273hr in a 5.3 224/230 .581/.592 114lsa and it was on the verge of too big lol.. the heads are where you are gonna make your power not a huge camshaft.. a 6.0l is a better start for all motor.. i guess you could spray the hell out of that 4.8 tho haha.. maybe build a turbo for it..
Old 01-18-2012, 01:00 AM
GarrettT/A's Avatar
More like a 5000 stall and 4:10's at least is what you will need for even that cam. Im doin a 232/234 in a 4.8 and i fully expect it to be a dog below 5k, boost will help though.
Old 01-18-2012, 10:28 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
WAY too big for a 4.8L in a Camaro! I'd be focusing on the high-teens or low-220's intake duration (depending on bolt-ons, converter, etc)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-18-2012, 12:05 PM
NemeSS's Avatar
First thing u gotta do is raise the compression of the 4.8. By having the heads milled if u want to run long duration cams in a 4.8
Not necessary but helps improve acceleration response.
Old 01-18-2012, 12:37 PM
^^I'd agree and add along with more compression more cubic inches...even with 11:1 static compression, a high 230's intake duration camshaft is too big with 4.8L of displacement in about a 3500lb car.
__________________
Quick Reply: 4.8 with ms3 or????
