Truck alternator not energizing via ECM
I know, another alternator thread... I did some searching and found enough info to get me where I'm at, but now I'm stumped.
The alternator is hooked up through the factory ECM (Blue/Green 2004 LQ4). The alternator was not working, so I tested the two wires going into the regulator and the green one has 12v, but the brown energizer wire has 0v. I wired the alternator manually using the resistor method and the alternator works fine.
I'd like to have the ECM control things rather than using the work-around method with the resistor. Any ideas why the ECM wouldn't put out a signal through the brown wire? Everything appears connected properly. Is there even an advantage to having the ECM control the alternator?
Thanks.
Thanks.
