Drag Racing Results - 12.1@131 98 ls1 s475 6 speed
95maroz28
01-15-2012, 02:31 AM
made a few passes tonight on 9lbs and 107. couldnt launch for shit on 315 nittos but made a few passes 12.19@ 131 and 12.0@ 128. gonna get a rear and try to get it in the 11s
boss79z
01-15-2012, 12:24 PM
Lot MPH there!
95maroz28
01-15-2012, 12:29 PM
yeah man its picks up once moving but i need a rear. when you going to get yours going? stock bottom end? . i really wanted an eleven but just couldnt get it lol
95maroz28
01-15-2012, 04:22 PM
heres a slip
joelster
01-15-2012, 05:16 PM
You picked up 37mph on the back half, lol. That's insane!
Scooter76
01-15-2012, 08:28 PM
Wow ! with that mph you will probly skip the 11"s and jump into the 10's with no problem !
Imstock2
01-16-2012, 01:58 PM
useally a 128+ trap speed is a deep 10 sec car
MattSapp95_T/A
01-29-2012, 08:44 PM
Car is moving like crazy on the big end... your 60' has a TON of room for improvement you can get a half of second off just from there!
Your Mph will come down a little once you hook up good but your ET should improve drastically!
your a 12bolt/9 inch and some Slicks away from consistent 10 second passes!
gsd2000
07-16-2012, 02:33 PM
any more details on the car like turbo spec etc
speedtigger
07-16-2012, 02:40 PM
What they said!
95maroz28
07-16-2012, 05:07 PM
its just the standard 1.32 ar s475 on a stock ls1 with bullet cam, springs and ud pulley
senicalj4579
07-16-2012, 06:55 PM
wow get the 60' down hahaha
Niiiiice mph!
gsd2000
07-17-2012, 08:04 AM
Cool how laggy is the turbo
gsd2000
07-17-2012, 08:05 AM
What gears do you have in the rear?
95maroz28
07-17-2012, 06:06 PM
stock rear 3.42, its always had a bad second syncro keeping me from slamming second at the track or w/e but tranny/clutch is getting replaced now.
It is a little laggy when hit from low rpm but have no problems spooling if i drive it like im racing.:drive:
gsd2000
07-18-2012, 12:03 AM
What sort of rpm are you hitting full boost by?
itsslow98
07-18-2012, 12:34 AM
Get yourself a rear, good tires, and a 2 step and come out on some boost. 10s will be no issue as long as you have suspension to put it down.
gsd2000
09-06-2012, 03:11 AM
any more updates
95maroz28
09-23-2012, 07:12 PM
Ran it on 7lbs 12.1 126 2.2 60' first pass. Turned it up somewhere around 8 and coughed up a rod in 4th around 120 or so. This piece was just sitting on the rack lol oops hopefully have it running again in Nov with forged internals and 14lbs.
a-low
09-23-2012, 10:46 PM
Sorry to hear that. Im really looking into the same turbo with a smaller ar for a 5.3.
mrstepheneades
03-23-2013, 09:15 PM
I'm doing the same turbo setup with meth injection and a custom grind 600 plus lift cam from tick. Also on a stock ls1 and six speed. Good to hear positive things about the setup. Besides to rod death lol... mine will see no track so maybe will last little longer.
