P0171 p0174 system running too lean bank1 and 2
Sounds like I burned my o2's right? Had ran the car with an open y pipe for a month and these codes come on and off. Car idles a lil rough and jerks at low rpm not too mention it feels like it got its ***** cut off. Seems like it loss power.must be since the computer isn't reading the o2 right?any help will be appreciated.
Car has long tubes
Car has long tubes
Car has long tubes
Car has long tubes
I had the same issue when I got my car, was fine when normally driving but when hammering on it CEL would come on. Fuel trims were fine normally but when hammering on it both sensors went lean. Hooked up a fuel pressure gauge and sure enough pressure was dropping at WOT at around 3k RPM.... Stock fuel pump couldn't keep up anymore...
I have a fuel pressure gauge (shitty one) you can hook up and tape to your windshield if you want to check it (I'm in Vista/San marcos)
