Canadian Members - Ontario guys, do longtubes with emissions fittings pass your visual?
92SilverSHO
01-16-2012, 06:17 PM
Is it as tough as Nazifornia inspection or no?
flame
01-16-2012, 07:01 PM
They don't do a visual at the test center anymore. If it passes the sniffer you can get your sticker. The sniffer will be gone soon for 98+ too just a diagnostic plug on test. The MOE roadside checks will look for everything to be there. Never been through one but I don't see a problem aslong as everything is still there and hooked up.
Mischief007
01-17-2012, 01:20 PM
Can you elaborate on that 98+ no sniffer test? How would it work on an OBD1 car which really doesn't have anything. Mine is a 95 so OBD1 with that OBD2 plug.
flame
01-17-2012, 05:09 PM
97 and older is 2 speed idle sniffer no more dyno means no more Nox just HC and CO
transamtom
01-18-2012, 07:45 AM
When are they changing to the DL test only?
flame
01-18-2012, 11:33 AM
It is starting to be phased in now. The areas that had drive clean from the get go will be the first to switch.
gmdoctor
01-25-2012, 02:01 PM
More important, will removing certain pcm codes with programs like hp tuner cause a diagnostic "not run" or "passed"
