Just flex honed my block, let me know what you all think
Ill let a buddy of mines measure the bores for me sometime this week. I used a 240 grit as recommended for hasting rings. I deleted the old pics i had of the cylinder walls but the crosshatches where highly visible and the motor ran fine. No blowby and didnt burn oil. I wanted to replace cam bearings and it ultimately led to this because i couldnt leave well enough alone lol. The block had around 125k on it. I got another set of 04 ls6 rods and pistons with roun 1500 miles on em that i will be sticking in.
Modern rings dont usually require that rough a finish any more.....they are "rounder" for lack of a better word and seal up quickly without the need of a rougher finish which creates more drag and more metal transfer everywhere on break in as the new rings knock the peaks (and folds) of the metal from the cross hatch/hone (also creating faster erosion of the rings over time). A 400 stone would have been more desirable in my opinion from the standpoint of performance, cleaner break in, and longer ring life.....320 if you prefer a courser finish perhaps.
I bet when you turn that engine over when the short block is assembled it will make quite a bit of noise from the cylinder finish and rings riding on top of that.
It will probably run fine....but in the future (and for the benefit of others reading) you might consider a finer grit stone to break the glaze and seat a new set of rings.....the real key are round bores with minimal taper.
Good luck with the build....
Here is a not so great shot of my 454 (not so great from the standpoint of its hard to see a close up shot of the wall finish).....but its obvious the cylinder wall is almost glowing in comparison.....this is even finer than a 600 finish but I have thin rings that seat quickly and are extremely round and lapped perfectly flat as well. A finish in between yours and this build is probably the happy medium for the average hot rodder running a typical 1.5 mm thick ring set because if the machine work isn't spot (regarding a perfectly round hole) a rougher hone than featured here is slightly more desirable.
Hope this helps.....
-Tony
-Tony
1 Post
I will check tonight when I get home, but I believe I used a 320 grit hone on my block. But I think that was what GM recommended, I would follow your ring manufacturer's instructions.
