1998 LS1 PCM, Harness and injectors
Category: Accessories
Price: $50
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TX
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have a PCM off a 1998 Firebird, which I have a tuning license for, so let me know what you changed and I can tune it---- $150 shipped
I have a LS1 harness that goes with the 1998 PCM, it is in need of a VSS pigtail though. Also, I think something might be wrong with it as it was causing a problem once it goes into closed loop and uses the oxygen sensors. I would go through it with a fine tooth comb. Because of this, I am selling it for $100 shipped. It is a "painless wiring" style harness, everything is labeled and it is a standalone harness, still in new shape. It was made by some random person. Then again, it might not have an issue with the harness at all as the engine wasn't running the correct fuel rail (I swapped harness/pcm/fuel rail and it ran good after that). It is a automatic transmission harness
Let me know if you would like some pictures
