Stereo & Electronics - Double din HU installation for Camaro.
sssalah
01-20-2012, 09:46 AM
I got an ebay head unit which is chinese with 7"touch screen and being covered by double d with the bezel. I've mocked the HU but it is interfering with the AC ducting and still sticking out more than an inch (total depth of unit is around 7.5"). What's the regular depth of more hi end HU like Poineer and Kenwood and what exactly needs to be done in terms of clearancing for the head unit to fit.
Jons02rs
01-31-2012, 07:17 PM
Did you cut the palstic tab that sticks up and remove the metal bracket that sits behind the factory radio.
sssalah
01-31-2012, 10:09 PM
Welcome to the board, no haven't done any cutting yet. I'm thinking that even after taking that piece out the radio will contact the AC duct before it sit flush. Anyway the bezel has not arrived yet, so we'll see how it goes by then.
TruBloodTransAm
02-01-2012, 01:02 AM
For ALMOST ALL aftermarket headunits, the metal bracket in the back needs to be cut off. I believe with the double din units you also have to shave a little towards the top opening, someone correct me if I'm wrong.
http://img408.imageshack.us/img408/5363/dsc00236ej.jpg
http://img12.imageshack.us/img12/4473/dsc00265xq.jpg
On my Formula, that metal tab at the back had a plastic covering. I cut off the plastic part of it and bent the metal part down out of the way.
bill12690
02-01-2012, 09:53 PM
In mine I just bent the metal tab back, didn't cut it or anything.
here's my install, if it helps any:
http://ls1tech.com/forums/stereo-electronics/1468396-my-z130bt-install-pic-heavy.html
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
