Advanced Engineering Tech - moving engine back
View Full Version : moving engine back
mark21742
01-20-2012, 12:49 PM
How much could i gain from moving the engine in my 04 GTO further back in the car? I'm talking about moving back around a foot or so, not mid engined.....I'm 5'6" and have MORE than enough room in the drivers seat with the cage, so that is not a problem to think about or deal with.
Main question, without room constraint, since the GTO is inherently nose heavy would there be a noticeable gain in handling and dead hook off the line grip by moving the engine so in would sit more like the engine in the f-bodies (partially under the cowl).
Pocket
01-21-2012, 09:48 AM
You'd have to redesign just about everything. This wouldnt be a street car venture
Modify the suspension to work with what you've got for now. If this is a track only car, then think about braking out the saws
mark21742
01-21-2012, 10:27 AM
This is more of a "what if", than a hey I'm thinking about it.....I've built full tube chassis cars front and mid engined, but do not plan on doing this to this car, just wondering the effects
Pocket
01-21-2012, 07:55 PM
In general moving the engine rearward and lower to the ground moves the CG to a more favorable location for hard launches. Cornering ability is dependent on how the suspension is setup. Run a simulation program like susprog3d
RyanEricW
01-23-2012, 05:39 AM
get a jig saw, welder, and take lots of pics when you hack it up so we can laugh at you when you fuck it up
mark21742
01-23-2012, 06:30 AM
I'll check that program out Pocket!
Ryan get it right. It's a sawzall, not a jig saw lol
chuntington101
01-23-2012, 06:58 AM
I personally would loke at moving heavey items to the rear of the car / lighting the front end before looking into ways to move the engine further back. Not sure what the front end hardware is like on the GTo but there should be some saving in bolt on parts. If you are happy to do a little cutting and welding there could be big savings without having to move the engine at all!
Chris.
mark21742
01-23-2012, 09:28 AM
Well see this is why I asked this question about the GTO in particular. The car is naturally nose heavy and looking at it compared to say the F-body the largest difference is engine placement.....the F-body's engine being roughly a foot further back in the chassis compared the the GTO, and what advantages this has.
