Help with Nitrous 4.8 build
Old 01-21-2012, 11:18 AM
buddhaz06's Avatar
Default Help with Nitrous 4.8 build
Hi I'm currently trying to get ideas for a nitrous setup 4.8. Stock 80k mile short block, what heads and compression should I go with? I was thinking either a 243 head or milled 317's id like to spray 175-250. And also I see nitrous cams are in the .600 lift range, big 240-260 duration and rpm range of 2400-7200. Would a cam like that be way too big for a 4.8? Plan on running a victor jr with plate and elbow. Any input would be great! Only thing I have now is the 4.8 and I have 2 sets of 862 heads and some 317's
Old 01-22-2012, 02:55 AM
Fbodyjunkie06's Avatar
I wouldn't use 317's on a 4.8. 862's may be no problem if the valves are stock, I'd get a set of older 5.3 heads with the smaller intake valve.
Old 01-22-2012, 11:34 AM
dnkynrbk's Avatar
If you can find a set of LS6 243 heads that would be best.
Old 01-22-2012, 12:01 PM
buddhaz06's Avatar
Ya I think 243's would be the way to go
Why smaller 5.3 heads? Dont I want bigger valves?
Old 01-22-2012, 06:25 PM
Bore size and valve shrouding
Old 01-23-2012, 05:54 PM
Firehawk441's Avatar
That's what I would use. I wouldn't even consider a 5.3 head.
Old 01-23-2012, 08:44 PM
Because of the smaller valve?
Is this going to be a strictly nitrous motor?
Old 01-24-2012, 12:07 AM
buddhaz06's Avatar
243 head would lower my compression to 9:1. I think I'll go with milled stock heads so is not a dog on motor.
Old 01-24-2012, 12:08 AM
buddhaz06's Avatar
It'll be nitrous at the track. Want it t have a lil get up n/a
Old 01-25-2012, 09:38 AM
What CR would the 5.3 heads give you? Like I said at first I'd use the 5.3 heads on a 4.8.
Is this going to be a track only car?
Old 01-25-2012, 04:17 PM
Nitro Dave's Nitrous Outlet's Avatar
Im not sure what head would be the best option on the 4.8 so I am of no help there. I did want to say if you decide to go with a 243 head I have a set of ported and extremely milled heads I would make you a good deal on.
https://ls1tech.com/forums/texas-cla...243-heads.html
Old 01-25-2012, 05:03 PM
Accually, after re-reading the OP's 1st post, I'll take what I said back.
The OP wants a stock, 80,000 mile 4.8 with a Vic Jr. Intake and 240 + duration.
I'd rather not involve myself with this.
Old 01-25-2012, 07:48 PM
buddhaz06's Avatar
well the 5.3 heads and 4.8 heads are the same. 862's. stock is 9.5:1. i figure mill them just a little, and get a thinner mls gasket. prolly be between 9.7-10:1.
yes pretty much track only. it'll be driven to track, roughly 15 miles each way. im leaning towards a 580-590 lift, and iwant the victor jr because i want a metal intake and i see it being the best option, because i can run a carb style nitrous plate.
243 heads will lower my compression a lil much for me. i didnt realize they were 9.5:1 stock. a friend of mine made 305rwhp with a 224r cam and headers with his 4.8 pickup. and ive heard of several guys running 200 shot on 100% stock trucks.
Old 01-27-2012, 09:05 AM
Quick Reply: Help with Nitrous 4.8 build
