Fueling & Injection - Injector size OK???
parks450
01-21-2012, 06:02 PM
Ok I'm not sure if my LS2 (33lb) injectors are enough for my setup anymore, I would like to stick with LS2 style injectors so I done have to buy adapters ETC. Any help with letting me know what injectors are good let me know. So I need your guys .02
My specs on the motor are as follow:
Iron block 5.3, Bored to LS1 specs and LS1 rotating assembly
TSP Torquer V2 CAM
FAST 102mm intake
LS6 heads, ported on exhaust side
Im not sure If they will suffice, although I think I will be fine. Let me know what you guys think. Thank you, John
01ssreda4
01-21-2012, 11:51 PM
I think you could get by but I'd like to see a 36-42 pounder on this setup. Have you talked to FIC about re-jetting your stock injectors?
ZL1Killa
01-22-2012, 07:28 AM
talk to FIC. Fuel injector connection
FICINJECTORS
01-22-2012, 10:05 AM
TSP Torquer V2 CAM
FAST 102mm intake
We have a special on ls2 injectors in all sizes to 60lbs, if you trade in yours it's 200.00 for the set any size to 60 with a 3 yr warranty!,,
parks450
01-22-2012, 10:34 AM
REALLY!!! Dam thats a good deal, I will be getting a hold of you this week sometime. What do you give for my stock injectors?
FICINJECTORS
01-22-2012, 01:47 PM
REALLY!!! Dam thats a good deal, I will be getting a hold of you this week sometime. What do you give for my stock injectors?the 200 is the price already including the ls2 set. if you have another set of ls1's i will buy them too. we will talk when you call me
RyanEricW
01-23-2012, 05:36 AM
watch your afr trial n error
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
