Truck Harness to Camaro MAF
Old 01-21-2012, 10:47 PM
74ventura's Avatar
Default Truck Harness to Camaro MAF
Im working on my LS swap into my Ventura and in the process of gathering parts I came across a cheap 02 SS MAF. My harness came out of a 06 Suburban. I noticed the MAF sensor only has 3 terminals, but my harness connector has 5 wires to it. Any way to make this work, or best to by a truck MAF?
Thanks
Old 01-21-2012, 11:06 PM
i r teh noobz's Avatar
The truck MAF has a built-in IAT. Many swappers including myself remove the IAT wires and use the Camaro IAT with a truck MAF due to heat soak of the housing throwing off the IAT readings. I don't know if the MAF part itself is any different, but I'd assume they aren't.
aknovaman's Avatar
Wink
pink, yellow and black/white stripe go to maf, tan and black go to inlet air temp sensor.
F-body schematic
http://www.lt1swap.com/pictures/9_engine_sensors.gif
Truck schematic
http://www.lt1swap.com/pictures/fig_2.gif
Tuner must adjust MAF table for truck MAF size too.
Old 01-24-2012, 08:35 PM
74ventura's Avatar
Thanks for the help, hope to have it running soon!
Old 01-25-2012, 08:34 AM
Project Builder's Avatar
Something I will need to remember as I will most likely come acroos the same issue.
Quick Reply: Truck Harness to Camaro MAF
