After ported heads and other changes will I be able to drive to my tuner?
Like the title states I will soon be swapping over to some ported heads and some bosch III 41lb injectors. My question is will my car be drivable to my tuner if I have a mailorder tune from Texas Speed that was for the cam. I currently live in Kyle,TX which is about 2 1/2 hrs from Victoria, TX which pat g will be tuning my ride. So what do ya'll think will it be drivable or more than a hassle.
Yep you ll be able to. I swapped heads, cam, intake, gears, injectors, ported tb, wires, plugs, did free mods, and had tranny built. Been driving the car every other day to work 1 hour round trip for three months with no dyno tune. Only a tunebyfrost mail order tune with no problems.
LS1Tech Premium Sponsor
You should have no problem driving with the heads installed. If you swap injectors then you really need to get the tune done before driving!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
