427 Stroker Help
Old 03-17-2004, 10:19 PM
Z28 10 SECOND CLUB's Avatar
Post 427 Stroker Help
hey i currently have a 1999 Z28. i run 12.19@113mph on motor and 11.62@115mph on spray. i am currently having a 427 stroker motor with lunati billet crank pistons rods and a 595/604 inch lift nos cam. i currently have these mods:
whisper ram air kit
whisper air lid
granatelli mas air flow sensor for nitrous
ls6 intake manifold
msd plug wires
ngk plugs
tci +1500 stall torque converter
bmr strut tower brace
Finish Line Performance long tube headers
cats removed
borla cat back exhaust sytem
3.73:1 strange gear
bmr subframe connectors
bmr lower controll arms
NOS dry kit 125 shot hooked up to the ram air underneeth air lid
mickey thompson et streets 26x10.5-16
i am getting a stage 5 trans moser 12 bolt 8 point roll cage 250-300 shot wet kit bigger in tank pump and accel 34lb/hr injectors qa1 shocks and springs and vigilante converter. im hoping to run low 9's high 8's. is this a possibility and if i do in fact run low 9's or high 8's where can i race in some sort of orginzed racing. where i can make cash. i know of nhra eliminators but i dont run 7's or 6's what kinda of options are there besides bracket racing?
thanx for your time.
Old 03-17-2004, 11:02 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Seems like a vig multi disc set up might be better for what you want to do than a vig 3600.
Might want to settle on a set of heads and see what the flow numbers are and that the head porter suggest for cam selection before deciding on the cam.
TEA has a custom NOS exhaust port for their heads. Call TEA and talk with Brian about your combo. I think that would be an excellent starting point. Brian has made 690rwhp with a 346 and ran 9's with his NOS heads.
Old 03-17-2004, 11:19 PM
Chicago Crew UnderBoss's Avatar
Sounds like a GREAT GAME plan that you have layed out for your baby and i agree get the Best Heads that you can afford matched to your choosen N20 friendly cam and the 9s should be yours on a 250 shot, assuming traction and that everything holds up!
BEST OF LUCK on your ENDEAVORS!
