Need PS pulley for LQ4 transplant
Did a search and can't find a confirmed fit/part # for a LQ4 with the truck acessories in a 69 Chevelle. I do have a Jeep GC steering box installed. One search said a Dorman 300-020 would work, but its still too big and hits the box. Any suggestions appreciated.
72 Olds, L59, Jeep box, Dorman 300-201
A couple links
https://ls1tech.com/forums/conversio...2-build-3.html
https://ls1tech.com/forums/conversio...swap-pics.html
A couple links
The problem with the 201 is that if you push the pulley on the shaft to the correct depth, it's too far on to remove with a standard puller. A press can remove it though.
I used 3 spacers on the bolts between the pump and truck bracket so mine can be removed with the puller.
Not sure on other pulleys.
Basically just moving the pump towards the rear right? How do you guys know when the puller is lined-up properly with the other pullies?
Honestly at under $15, I probably will just break it off to get to the bolts and remove the pump. But if I'm stuck in Roosterpuke, Arkansas and cant get a pulley, there's at least the option of reusing the pulley that's on there.
It only took me 15 minutes with a hole saw to cut 3 0.2" spacers out of aluminum.
To align any pulley, lay a strait edge across the balancer, measure to one of the groves/ridges on the balancer. Extend the strait edge to the new pulley and measure to the same groove/ridge. Install until they're the same measurement.
Or you can buy a laser alignment tool.
Some of the plastic ones have metal collars in them where they are pressed onto the shaft. I know this because I needed to pull one of mine for some reason but had pushed it on extra far, tried to use a 3 jaw puller and broke the pulley...after busting the rest of it off I still had to cut off the collar to fully remove everything.
I have 2 pulleys sitting in my basement GM 10166335 and Ford: E8UA-3d673-BA. Both approximately the same outer diameter. If you want to try the 2 of them to test things out, I'll sell them cheap if you come pick them up...I'm in Philly burbs in NJ.
Yes. Installed with a press and it broke at random one day when I tried to start my car. I can think of no reason to use a plastic pulley when metal ones are available. A combination of being pressed on a tab more and shimming the pump gets everything lined up and the pulley still removable with a tool. As mentioned, the metal collar left after the plastic breaks is a pain in the ***.
