Eastern Members - failed Mass inspection
massls1guy
01-24-2012, 10:28 PM
Because my headlight lenses were scratched to hell. He was right, didn't expect to fail for that though. Looks better now.
Before (not dirt):
http://i275.photobucket.com/albums/jj282/marklsx/car/IMG_7439.jpg
After:
http://i275.photobucket.com/albums/jj282/marklsx/car/IMG_7453.jpg
Slowhawk
01-25-2012, 07:47 AM
My next door detailer does them. They look like new when he's done for $75.
rjlawlor646
01-25-2012, 12:12 PM
I always try to get my inspection done at some half way shop to avoid any issues. My exhaust and tint won't pass, and my horn doesn't work but I've never been questioned. What did you use on the headlights thought? I like the 3m kit for restoring headlights.
Formula413
01-25-2012, 04:00 PM
I would also like to know what you used on them.
rdm85mcss
01-25-2012, 05:55 PM
For a cheap fix use some easy-off oven cleaner and a damp sponge. Works great but doesn't last forever.
marklsx
01-25-2012, 10:47 PM
I did some research online and saw people with good results wet sanding with 400 grit, then 1000, then 2000, then polish. I ended up getting the Rainx kit at Autozone for $15. It has 3 abrasive pad grits, polish compound, polish cloth & sealant. The corsest pad in the kit didn't seem coarse enough so I started with some 400 grit I had and then used the 3 pad grits, then polish.
The final step is a spray on sealant. It made it look great and really clear. This morning honestly it looked a tiny bit cloudy compared to the 'after' pic. Still a giant improvement.
DannoWS6
01-26-2012, 08:37 AM
Most of the time you can start off with an aggressive 3" pad and some 1500 grit compound and work your way up from there. Usually what I start with using a porter cable. 400 grit wetsand seems pretty aggressive, but I could see 1000 being needed if its bad enough.
You can't really screw up a headlight, so if it works it works.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
