4.8L into 4th Gen FBody
Old 01-25-2012, 02:40 AM
Need4Camaro's Avatar
Default 4.8L into 4th Gen FBody
I am just... curious, and this is going from a V6 to a V8, but What would a N/A 4.8L with full boltons (besides Cam and Heads) do power wise?
Also if later I upgraded the heads / cam, what kind of power could I make out of it?
And finally what would a procharged or turbo'd 4.8L do at about 8 PSI?
Old 01-25-2012, 06:42 AM
turbinesurgeon's Avatar
This question would be worth re-posting in an engine internal section, would get better feed-back there.
n/a 4.8 with full bolts ons could get up as high as 400hp without too much trouble, nice heads would be the key there. Force-fed set ups would get closer to 600hp. And for the same money as a procharger set up you could bore and stroke a 4.8 out to a 383 without too many issues. That's worth about 500hp.
Here's the real question, how much are you wanting to spend on your 4.8 on top of the install into your 4th gen? Your budget will give you a better idea of how much power you can build.
Old 01-25-2012, 07:12 AM
Captain Double Post
BOBS99SS's Avatar
imo i wouldnt go 4.8 there are great deal on 6l truck blocks,ls2, and so on, 5.3 with some boost is a great budget setup as well
Old 01-25-2012, 07:17 AM
DarkFox118's Avatar
4.8 is very capable under boost, as is the 5.3.
NA? well.. I wouldn't bother really on a 4.8. 5.3... eh if you want close to ls1 stock power for a budget maybe. 6L would be the best bet for that route.
Old 01-25-2012, 11:05 AM
Eh, decent 6.0L LQ4's are running about $1,200 these days. A 4.8L is only 1/3rd of the price at around $400. I might go with the 4.8L and have it stroked to a 383 later.
Thing is, my 3.8L is about to die and I've been planning on doing a V8 swap for a long time but I'm on a budget. A 6.0L will probably be slightly too expensive. A 5.3L can probably be done with ease but I noticed how inexpensive the 4.8's were and it got me to thinking.
Old 01-25-2012, 08:23 PM
wildcamaro's Avatar
Yea you can get 4.8/5.3 for around the same price...I would get whatever you can get with the best mileage/$ so no rebuilding would be neccesary
Old 01-25-2012, 08:40 PM
Being on a budget, this makes the most sense. Get the LSX installed and running, then later you can build up a long block for a swap.
Old 01-26-2012, 10:45 PM
CoreyZ/28's Avatar
Hotrod mag did a 4.8 build not too long ago. Basically a stock 4.8, small cam, fast 92 intake and tb and boosted the **** out of it with twin 67mm ebay turbos and supporting mods and it held together at nearly 27 psi which is where the stock coilpacks couldnt maintain a spark and make upwards of 1200fwhp numerous times. Seems like u could dial the boost back and run 700-800 hp for a while for a relatively cheap price for the power made.
Old 01-27-2012, 05:21 AM
That is absolutely insane.
One thing I've wondered is where to mount Turbo's in an LSX powered 4th Gen F-Body.
If I had the extra money I would consider doing that right now but I'd have to put it off - Im also wondering what heads/cam will do.
Old 01-27-2012, 11:35 AM
99VetteFRC's Avatar
I agree ^... I am doing very similar build in my Chevelle. 2 t70's on stock motor with LS6 valvesprings. Can't wait to install it.
Old 01-27-2012, 04:07 PM
What about a Procharger? would that be a good addition to a 4.8L? What should I expect out of that?
I am very tempted to go for the Turbo but it's such a squeeze with the big V8 in there and all... I would have to go with a Tubular K-Member wouldnt I?
Quick Reply: 4.8L into 4th Gen FBody
