Generation IV External Engine - l92 coolant crossover
97badass
01-25-2012, 07:16 AM
Anyone have pics? I can get a 4 corner for a ls1... Will that work?
97badass
01-25-2012, 07:35 AM
Answer: only if I modify my intake, you have to use one from an ls3 since the rear ports are plugged and only need the fronts. ;) damn, Google is good for something.
1A Dan
01-25-2012, 11:16 AM
i opted to unplug my rear ports on my l92 heads and running the tubes on all 4 corners. rigged up a l92 & ls3 front setup pair to do everything for now, but the an fittings seem like such a cleaner setup
97badass
01-25-2012, 12:09 PM
Any pics or a write up on the an fittings?
1A Dan
01-25-2012, 12:47 PM
i havent installed mine yet, but there are a couple of different places that offer the blocks for use with AN fittings. The ones I got were not from a vendor here, so I don't think I can post a link.
97badass
01-25-2012, 12:49 PM
Then send me a pm ;)
Jontall
01-25-2012, 10:32 PM
Better read this: http://www.norotors.com/index.php?topic=6547.0
Put http here>://www.kurturbanperformance.com/water-line-adapters.html
97badass
01-26-2012, 07:18 AM
The norotors link just confused me more... He said to run front or rear. Then someone said all 4... I'm just going to get 2 blocks and some an fittings and run it to the top of the waterpump
Jontall
01-26-2012, 03:17 PM
They are saying that GM Engineers/race teams have found that the 2 rear vents need to be blocked. The front 2 steam vents should be run to a surge tank with a pressurized radiator cap and then back to the radiator with a free flowing radiator cap installed.
LongIsland63SS409
01-29-2012, 10:05 AM
Interesting would like to see some pics of that setup.
Thanks,
Mike
Gray86hatch
01-29-2012, 12:20 PM
Here is how mine was set up. I now have it to a bung welded in the radiator
http://i1012.photobucket.com/albums/af247/gray86hatch/DSC09051.jpg
Tim
LPE 403
01-29-2012, 02:38 PM
AN fiittings here into a block.
http://i179.photobucket.com/albums/w291/lpe403/Car%20Build/12-23-11.jpg
http://i179.photobucket.com/albums/w291/lpe403/Car%20Build/8758f561.jpg
Mike454SS
01-29-2012, 08:02 PM
Kurt Urban is a sponsor...his name on here is 427...and I believe he's a sponsor of both LS1Tech and Performance Trucks.
1lejohn
01-31-2012, 06:39 PM
Geez the stock LS1 will work.
1lejohn
01-31-2012, 06:40 PM
Looks like the old C5R race motor, but with after market parts
On my L92 I clipped the tube with hose fitting and drilled and tapped for 1/8 pipe AN-4 90 degree fitting and then ran a steel braided -4 hose to the water pump.
LPE 403
01-31-2012, 07:19 PM
Lol, funny you say that. Looked one up a few weeks back and there are def some similarities.
1lejohn
01-31-2012, 07:56 PM
whats it going in. Bad azzz for sure.
ShredSled
02-02-2012, 08:04 AM
just wondering if you happen to have more info on this?
I'm currently running 2 rear ports plugged, and just front crossover, but when I did manifold swap I was considering connecting all 4, but if what you say is valid, I will not...
black-sinner
07-20-2012, 07:15 PM
I would also be interested in that
bww3588
07-24-2012, 02:06 AM
Plug them if you want 7 and 8 to run hot. There is a reason most people opt to put a little extra effort into connecting all 4 rather than blocking the rears off.
rumblebox
08-06-2012, 07:36 AM
Is it safe to drill them out without pulling the heads?
