Is this block ok?
Old 01-25-2012, 01:29 PM
gpr
gpr's Avatar
Default Is this block ok?
I took some pics. Engine spun a bearing which i think can be line bored out, then run an oversized bearing. I have attached pic, does this cap look ok?
However i was noticing in the head bolt where the dowl goes at the back of the block, there is this hole. It looks like possibly the machining for the tranny bolt (which is the hole i'm using on the engine stand) got into the head bolt area. Is this okay? is it gonna leak coolant or have issues?
Reason i ask is this cylinder also had coolant in the cylinder.
Attached Thumbnails Is this block ok?-20120123_203627.jpg   Is this block ok?-20120124_213539.jpg
Old 01-25-2012, 01:36 PM
gpr
gpr's Avatar
what the heck, how do you upload files to show up in the post? i only see red X's. I even shrunk the size so they are only 170k or something like that.
Old 01-25-2012, 01:54 PM
sepsis's Avatar
After you select the files to upload, do you hit the "Upload" button?
Then, you have to wait for it to finish uploading.
Old 01-25-2012, 02:10 PM
mark21742's Avatar
Upload your pics to Photobucket, then copy/paste the [I'm g] link into your post
Old 01-25-2012, 02:21 PM
5.3LJimmy's Avatar
I can't see the pics but I can tell you that it's normal for the transmission bolt hole to intersect the head bolt hole. The head bolts do not go into the water jacket so this is not an issue.
Old 01-25-2012, 03:06 PM
gpr
gpr's Avatar
Okay well if it is a common thing then i won't worry about it.
I did up load the pics and it showed them as uploaded. tried it several times and never worked. oh well...
