COMPLETE Solid roller setup
Category: Engine - Intake/Fuel
Price: $600
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I can't tell you brand names on most of the stuff but I have most of the specs.
The springs are 1.560 diameter duals plus damper with retainers and jumbo locks.
Comp Cams roller rockers (1.75) with studs and guide plates
The lifters are very lightweight (103 grams) solid rollers with steel and aluminum bodies.
3/8 diameter .120" wall chromoly pushrods
Double roller timing set
I put the cam in a block and came up with the following specs using a degree wheel. 248-250- 113 .600 - .620
This is everything you need to convert to a solid roller setup.
The whole deal had about 500 miles on it. Minor scuffs on the lifter bodies but that's about it.
I would guess this stuff probably cost about $2000, maybe more.
$550 takes it.
A&A Corvette Performance
477 Lambert St
Oxnard Ca 93036
805 278 4107
WWW.AACorvette.com
Andy@AACorvette.com
