Gen 5 Camaro Power-Adder Tech - Track times?
texada
01-25-2012, 04:43 PM
Guys, real curious about the track times and mph on the new Supercharged Camaros. Thinking about buying one and installing a Whipple on 10lbs, LT Headers, Magnaflow mufflers, 2600 stall converter. This car is really going to be for the wife:D How fast are you all running?
Thebeast916
01-25-2012, 11:14 PM
with those mods, assuming your are going to do radials, u will have a high 10, low 11 second car
Thebeast916
01-25-2012, 11:15 PM
also check out camaro5.com. hundreds of camaros with whipples on there
No Hope
01-28-2012, 03:06 AM
That website sucks, I wouldn't trust anything said on there.
Why do you want a 2600 stall converter? You won't need it if you're not installing a cam.
You get more bang for your buck with a Procharger. A Procharger will give you better track times. I would say low 11's. If you add some Drag Radials and suspension work. Your looking at high 10's. Make sure you find someone who is good at tuning trannys when you get it Dyno'ed.
A Whipple would be better if your going to do a lot of street racing.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
