243 milling n comp ?'s
Blocks at machine shop n pistons r supposed to b here friday .its a 6.0 bored. 040 and running flat tops. Question is whats gonna be my comp ration if i have the 243's milled. 01 just to make sur theyre cleaned up and try n raise comp ratio a little bit at the same time
Was gonna run my ms3 but its screwed. So thinking of running the 233/239 .anyone running this cam in a 370-371? thoughts on it?
Yeah hope they do chime in. HINT HINT,!!!! Just dont want any issuse just check to make sure clearance is ok and bolt it together. No flycutting or sending back cams .
