ls3 piston to valve clearance
Old 01-25-2012, 08:07 PM
ls-won-84c10's Avatar
Default ls3 piston to valve clearance
has anyone ran into piston to valve clearance problems with the ls3? ive been told that your kinda limited in terms of lift and duration when choosing a camshaft for this motor. my ls3 isnt exactly stock, has good rods and pistons in it, mahle forged flat tops with 4cc valve reliefs for the big ls3 intake valve, the deck has been cut about .003 to clean it up and the pistons come out above the deck .008 to .010. the heads have stock 70cc chambers, i dont think ill have any P/V clearance issues due to the big valve reliefs in the pistons. gimmie some input on this.
Old 01-25-2012, 10:25 PM
Mike @ New Era's Avatar
You probably have a good bit to work with, but need to know your cam profile.
Old 01-25-2012, 10:40 PM
Tainted's Avatar
Very vague details....
Old 01-25-2012, 11:53 PM
njc.corp's Avatar
Cool
at the end of the day you need to check if you have clearance or not
everything needs to be taken in
the pistons stick out
what gasket are you using
what is the cam profile
you just need to check
rule of thumb for the industry is 80 thou intake 100 thou exhaust
^^^ but everyone is different on what is tight or not-
CHECK
Old 01-26-2012, 01:04 AM
lsx408's Avatar
post some cam info.
Old 01-26-2012, 07:23 AM
Jim85IROC's Avatar
your valve reliefs will allow for significantly more cam duration than a stock LS3 with flat top pistons.
Old 01-26-2012, 07:39 AM
Default cam specs
i havent bought a camshaft yet, i dont think i should buy one until i figure out what i can get away with, there are bound to be some sort of baseline numbers to go by.
Old 01-26-2012, 10:19 AM
Tainted's Avatar
Have pat g spec you a cam. He can take all your build info, your goals and spec it out based on those things. $25 well spent imo
Old 01-26-2012, 09:32 PM
Default pat g
how do i get in touch with pat G?
Old 01-26-2012, 09:44 PM
1badeagle's Avatar
Just search his name and he has a link to his site in his signature.
Old 01-26-2012, 10:03 PM
Tainted's Avatar
Shazam
http://www.engpwrsys.com/index.php?a...&productId=216
Quick Reply: ls3 piston to valve clearance
