1969 camaro 6.0 swap questions!!
I recently bought a 03 LQ4 6.0 engine for my 69 Camaro. I was wondering is it will fit under the hood with that tall truck intake? Will it fit with a cowl hood? What about the oil pan , will it have to be changed? Thanks for the help!!
It will not fit unless you put a Cowl Hood on.
Would suggest you look into Mast or Holley oil pan if you want a cast one. If not, nost of the Steel ones well fit, but remote oil filter are required.
There are many build thread and info in the FAQ for the 1st gen F-Body swap.
BC
BC
