Ryan@Lingenfelter
01-26-2012, 12:36 PM
Lingenfelter has packaged a universal E85 fuel pump kit with a Bosch 46mm diameter body high flow in-tank turbine style fuel pump. This pump is compatible with E85 type fuel and is also compatible with pulse width modulated (PWM) type control system. Safe for voltage boosting up to 18 volts. Flows 350 lph at 43 psi. Kit includes fuel pump, hose barb style outlet fitting with check valve, wiring harness, and inlet filter.
http://www.lingenfelter.com/mm5/graphics/00000001/L760060000_900_350x233.jpg
In stock now, click here (http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Product_Code=L760070000&Store_Code=LPE&search=l760070000&offset=&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=)to place your order!
Thank you,
Ryan
Thank you,
Ryan
