Hows this LQ9 look?
Hows this LQ9 look?
Hi,
Any help would be greatly appreciated..its going in a 68 Camaro.
1) Does this set up look good for low-mid range power on a daily driver?
2) Any idea on horse power?
3) Any idea on compression?
4) Pump fuel ok?
5) Any re-considerations?
LQ9
LS3 heads
LS3 intake
96mm TB
Cam: 222/230 .597/.609" 114LSA +2 advance using EPS lobes on the intake side for maximum power and LXL lobes on the exhaust
4L80E
Ford 9" 3:70
1 7/8" headers
4) Pump fuel ok?
LQ9
LS3 heads
LS3 intake
96mm TB
4L80E
Ford 9" 3:70
1 7/8" headers
I actually hadnt even thought about a fuel pump yet (my ignorance prevails as this is my first build). Any suggestions?
or something similar. only draw back is you have to use a return style regulator.
if you have any specific questions about stalls or transmissions, Call Russel Culver over at TCI, He is a good guy and is always glad to help.
