Question about a cam.
Old 01-27-2012, 12:10 PM
WS64Mula's Avatar
Default Question about a cam.
I am lookin to get a cam for my car. It's a 00 Formula WS6 6 speed with long tubes and cats. Stock cat back. I am lookin for a stock like idle, but a big power gain. Has anyone use this cam from vengence racing? VRX1 Camshaft-220/220 .581/.581 114 LSA I'd like to know what yall think.
Old 01-27-2012, 01:33 PM
raulz28's Avatar
That would be very tame but you won't see a big power gain that cam looks pretty small. We are thinking of using a 228/230 .571/.573 112 LSA on my friends LQ4 and we are thinking that we might be able to go bigger.
Old 01-27-2012, 05:58 PM
Mr. Sir's Avatar
https://ls1tech.com/forums/dynamomet...k-results.html
Or simply ask Pat G.
The VRX1 will make moderate gains, but if you're looking at cams from Vengeance, the VRX2 would probably be a better choice. It would take a trained ear to tell the difference between the two, and power will be up around 10-12rwhp.
Old 01-27-2012, 08:28 PM
WS64Mula's Avatar
I'm also lookin at this cam.
228/228 .588"/.588" 114
Old 01-28-2012, 01:00 AM
99Bluz28's Avatar
Stock like idle, but no big power gain, not with a small cam. You'll have to compromise on the idle for more power with a cam only swap.
A TSP 228/228 114lsa would have a decent idle and a good DD power band, and power gain. If you're willing to go with a higher lift cam then a custom TSP 227(.614")/227(.614") 114lsa cam with LSL lobes will make more power than the 228(.588")/228(.588") 114lsa with XER lobes, if either one of those is to big for your needs then a 226(.585")/226(.585") 114lsa w/XER lobes might work better for you.
Old 01-28-2012, 02:06 AM
Mr. Sir's Avatar
If you do decide to pursue a more stock like cam, chances are you're trying to keep noise down in general, so I'd suggest eps/lsl/lxl lobes. At least for a sleeper type car.
Oh, and get rid of the stock catback. It's the most restrictive part of the stock exhaust. I actually change my mind about cam reccomendations now, get one of the CheaTR cams.
Quick Reply: Question about a cam.
