DIY hand finishing a cnc head?
I'm strongly considering a set of the General's cnc ls6 heads.
However, I'd like to smooth out any cnc marks they may have. What's the preferred method of doing that? I've got a die grinder with a nice selection of attachments, but am afraid I may end up doing excessive material removal even with a high grit flapper wheel.
Could I just wet sand them by hand with various grades of sandpaper, or what would you guys recommend?
Thanks!
Dan
Thanks!
Dan
Thanks!
Dan
Thanks!
Dan
Originally Posted by robertbartsch
i left mine with the deep scratches...
i was going to sand them down and was advised not to...
Thanks,
Dan
I don't see any reason why you shouldn't. Jantzer is hand finishing my Patriot heads right now. Most of the shop cars have "hand-finished CNC heads" that I have seen.
There is nothing wrong with hand finishing them, just dont change the shape and dont try and make them a mirror finish, a little rough is good, now the exhaust can me made to be a mirror finish it helps so carbon doesnt stick as well
hand finishing
You will not hurt anything by hand finishing your heads, but be careful not to take to much off. The best thing to use would be a 60 grit stone, thats the finish you need. The rougher you leave the intake the better the runner keeps the mixture churned up which in the longrun builds more power. Roughness in the intake does not hurt the flow.
LS1TECH Sponsor
hand finishing CNC heads
Thanks!
Dan
Thanks!
Dan
The exhaust side can be carefully sanded (don't hit the valve seat) using first sixty grit sanding rolls then finishing with 120 or finer depending on how much time you are willing to spend. I use a high speed cable driven Dumore grinder for this work.
Steve Demirjian
Race Engine Development
Originally Posted by Steve - Race Eng
I do quite of bit of flow testing at my shop as well as cylinder head development work. I can tell you from experience, leave the intake side as is. The flow will drop in most cases if you smooth out the machining marks. The ridges also help to keep the fuel mixed with the incoming air charge.
Steve Demirjian
Steve Demirjian
Dan
