Scavenge pump wiring harness?
Old 01-28-2012, 03:50 PM
95batmobile's Avatar
Default Scavenge pump wiring harness?
Hey guys i am looking for a wiring harness for my pump... im thinking about calling sts about what they have but i know their prices are high.. im getting a high quality pump to replace my cheap one but i don't wanna mess up the pump or the flow of the pump with my own wiring..
thanks
justin
Old 01-28-2012, 05:44 PM
bump bumpyy
Old 01-28-2012, 10:36 PM
bumppy
Old 01-28-2012, 10:44 PM
1BADAZZSS's Avatar
Last time I heard sts were selling there harness's for around $100 but that's been couple years ago.
But can't go wrong with a 30amp relay, in line fuse and some good gauge wire.
Old 01-29-2012, 07:27 AM
JAX04's Avatar
Its only two wires bud. IIRC, its red and black..... Cant mess that up. Red is power, black is ground. As Badazzss said, run a 4 prong relay, and a fuse, all is good.
You'll have maybe 20 bucks in it, if that???
Old 01-29-2012, 11:42 AM
i dont know what a 4 prong relay is or what it does lol right now i just have it wired up red and black wires thats it.. i didnt know if there was a more professional way to do it
Old 09-03-2012, 04:10 PM
JoshuaGrooms83's Avatar
im curios as well. whats the relay for exactly?
Old 09-03-2012, 04:52 PM
Cam72aro's Avatar
Old thread…. But a relay allows you to run a high amperage component without burning the switch up. Wire the switch to the relay, then the relay to component.
Old 09-03-2012, 05:31 PM
not as old as most i find lol
ok, got it.
so run from ignition "on" source(switch) > relay > 20AMP fuse > oil pump > Grounding source(circut comple). correct?
Old 10-27-2012, 11:00 PM
ok, alittle more clarity which way do i wire in the relay? im looking at a typical GM 4 prong relay, but not sure which way to run the circut.
Old 10-27-2012, 11:20 PM
FOUND A GREAT EXAMPLE. granted its a fuel pump but its pretty much the same idea.
http://www.enginebasics.com/Advanced...p%20relay.html
now i know how to wire a 4 prong relay to the oil pump and it explains it why it works. really cool actually
Old 11-03-2012, 08:13 PM
found a 4 prong relay and relay socket to make my wiring look more professional. looks like 16 gauge wire should suffice for power and ground supply wires
Old 12-12-2012, 10:01 AM
had another question on this, where should i have the oil pump wired to for a 12 volt source. The above link shows a wire going to the positive battery, but that would give a constant source obviously so i need a switched on location.
I was wondering if i should do the alternator but not sure. What else would be a good switch source so that the relay only gets voltage when the cars "on" and not constantly sucking up voltage.
Old 12-12-2012, 10:03 AM
JAX04's Avatar
4 prong relay,
Power from battery into it, out to the pump. Ground the relay, use the signal wire for the factory fuel pump to activate the relay, oil pump primes and runs with fuel pump.... Done
Old 12-12-2012, 10:38 AM
ah, ok and since the fuel pump is running off the racetronix hotwire kit, the stock power wire for the fuel pump should be ok
Old 12-12-2012, 11:16 AM
ibex37's Avatar
yeah it should work just check the wire with a voltage meter to verify you have a "switched" 12v source
Old 01-16-2013, 10:45 PM
was wondering since im here, i put a racetronics pump in and hotwire, can i some how wire the scavanger into the old fuel pump source? is so, how exactly
Old 01-17-2013, 01:19 AM
95bowtie's Avatar
Just buy a jegs fuel pump relay harness and be done. 30 bucks I think
Old 01-17-2013, 02:37 PM
NemeSS's Avatar
Ive used that jegs one a few times. Works good
Old 01-24-2013, 08:09 PM
i already have a relay so that parts ok, im just wondering which wire to tap into from the "old" fuel pump power wire. i cant find my racetronix instruction s from when i did the wire and fuel pump install
Quick Reply: Scavenge pump wiring harness?
