Drag Racing Results - Launching with DRs
jarheadtex
01-28-2012, 09:03 PM
I went to the track for the first time today with this car. I had a best 60 ft of 2.05. I was pretty much leaving like I would at a stop light. What RPM have any of your 10 bolts held up to. I know it will vary by track..etc. But next time I want to actually try to launch. Running an 8.5 1/8th is kinda embarrassing.
wantagofast
01-28-2012, 09:13 PM
Mine is auto but it loads at 2800rpm and thats nothing I would say 3000rpm is safe 5000 well no no
RacerXLs1
01-29-2012, 07:47 AM
Live around 2k. But don't just dump the clutch, slip it, you may even be able to go higher..
Doug G
01-29-2012, 08:23 AM
I've had best luck hooking at just over idle (1500-2000)
I know my car is different, but all you can do is to keep testing....try 2000...then 2500...then 3000. See where it works best, but be sure to do your burnout the same every time.
jarheadtex
01-29-2012, 12:05 PM
thanks for the info. I got the burnout down and think I will try slipping it from about 2-2500.
ROMERO98Z28
01-29-2012, 10:52 PM
good luck bro
silverls1z28ofdeath
02-06-2012, 10:01 PM
im running a stick on dr's and Ive done a 5000 dump on a bone stock ten bolt...I think people dont give a 10 bolt enough credit cuz Ive done five or six passes in one day and drove the car home 180 miles still with no problem
moge11
02-06-2012, 10:28 PM
I come out at 3900 no problem on street tires... probably go 4500 and come off the clutch a LOT faster with some drag radials.. i can come off at 3500 plus no problem on the street.. broke my ten bolt after a 3500 launch on a 3rd gear shift a couple weeks ago.
jarheadtex
02-06-2012, 11:08 PM
I slipped the clutch last weekend from 3500. Got me a 1.9 but smelled like I left half of the clutch on the track.....however I did get a new best 8.3@89
LS1rob00
02-07-2012, 02:30 AM
I usually slip the clutch from around 3250-3500. Can't be too slow though or you'll just burn it up.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
